[O2] Combi - błędy VCDS
  • Pieter93
    • 7
    mrfazi, 225/50 jest w Octavii Scout a do naszych pasuje 225/45/17 lub 205/50/17
  • qu_bek
    • 3936
    Obecny autoscan wykazał 4 błędy (pomoże je ktoś rozkodować i podać ewentualne przyczyny ich powstania) :?:
    VCDS Version: Beta 11.3.0
    Data version: 20110801
    Monday,28,January,2013,11:53:26:10074
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: XXXXXX1ZXXXXXXXXX Mileage: 148880km/92509miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 TB HW: 03G 906 021 AN
    Component: R4 1,9l EDC G000SG 2047
    Revision: --H09--- Serial number: SKX7Z0H932306L
    Coding: 0000071
    Shop #: WSC 21670 456 11584
    VCID: 72EFDEFB118B
    2 Faults Found:
    005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
    P161C - 000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 148705 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:02:23
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.63 V
    Bin. Bits: 00001100
    Temperature: -6.3°C
    Bin. Bits: 00110000
    005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
    P161D - 000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 148705 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:02:23
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.63 V
    Bin. Bits: 00001100
    Temperature: -6.3°C
    Bin. Bits: 00110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 113B201C09250001881104ED902100416800
    Shop #: WSC 73430 790 00000
    VCID: 74E3D8E36B9F
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1Z0 820 047 K HW: 1Z0 820 047 K
    Component: Climatic PQ35 140 0909
    Revision: 00140009 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 3B7133DF0641
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000005969006
    Coding: 09880F030004140043110D000000000000097F075C00000000 0000000000
    VCID: 33611BFF2E11
    Subsystem 1 - Part No: 1Z1 955 119 C
    Component: Wischer 170908 022 0601
    Coding: 00055223
    Shop #: WSC 21670
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q2 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD27GHW.
    Coding: 0020786
    VCID: 3D753DC71855
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
    Component: J0527 051 0101
    Coding: 0000042
    VCID: 7F0907CF52D9
    5 Faults Found:
    00576 - Terminal 15
    012 - Electrical Fault in Circuit - Intermittent
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1Z0 920 812 H HW: 1Z0 920 812 H
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: V0007000 Serial number: SKX7Z0H932306L
    Coding: 0003101
    Shop #: WSC 20300 456 177296
    VCID: 397D29D70C7D
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K089190373
    Coding: E9807F0E0002022302
    VCID: 356525E72065
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VD1 1614
    VCID: 397D29D70C7D
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 H HW: 1T0 959 701 H
    Component: Tuer-SG 006 1203
    Coding: 0000244
    VCID: 3C7330C3034F
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.068 H08 1901
    Shop #: WSC 73430 000 90108
    VCID: 356525E72065
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 80801A085283007F3F04850500084F01807CA0
    VCID: 83010B3FBE31
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 H HW: 1T0 959 702 H
    Coding: 0000244
    VCID: 3D753DC71855
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
    Component: Radio FO3 020 0041
    Revision: 00020000 Serial number: SKZ7Z3H0139640
    Coding: 0000400
    VCID: 2E570A8BC533
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
    Component: Tuer-SG 006 1301
    Coding: 0000144
    Shop #: WSC 73430 790 1012544
    VCID: 37792FEF3A69
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
    Coding: 0000144
    VCID: 387B2CD33777
    Address 76: Park Assist Labels: 1Z0-919-283.lbl
    Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
    Component: Parkhilfe 4-Kan H04 0020
    Coding: 0000001
    VCID: 3D753DC71855
    End ---------------------------------------------------------------------
    Obecnie -> Octavia II:
    Terminy Spotów Śląsko-Małopolskich
    • Mr0czny
      • 948
      • CHHB 2.0 TSI RS 220 KM
      2 Faults Found:
      sprawdzić świece żarowe czy grzeją i kable czy dają prąd
      5 Faults Found:
      00576 - Terminal 15
      z tego co piszą na
      TDIClub stacyjka do wymiany :|
      1 Fault Found:
      zobaczy czy ci lusterko kierowcy grzeje albo kabelki albo wkład do wymiany
      co do ostatniego to radio działa ?
      W pierwszej kolejnośći sprawdź akumulator bo taka ilość błędów związana z elektryką może świadczyć o tym ze po prostu aku już pada i na mrozie nie daje rady. Jeśli okaże sie że akumulator jest dobry to sprawdzaj po kolei to co Ci napisałem
        • 11351
        w silniku dwie świece żarowe - cylindry 3 i 4 do wymiany
        w sterowniku kierownicy błędy zasilania - coś z aku było?
        w sterowniku drzwi kierowcy - nie grzeje lusterko - wiązka/mata grzewcza?
        w sterowniku radia - błąd za niskiego zasilania - coś z aku było?
        • qu_bek
          • 3936
          Mr0czny, tak radio działa,
          No to najpierw wezmę się za sprawdzenie aku, a świecę pójdą wszystkie do wymiany.
          Czy coś z aku było tego nie wiem bo niedawno zakupiłem tą Czeszkę i zaczynam coś przy niej dłubać.
          Mr0czny, krzynol Dzięki za odpowiedzi
          • Mr0czny
            • 948
            qu_bek, 2008 rok to aku pewnie niewymieniany
            IMO dla świętego spokoju oprócz wymiany świec wymieniłbym tez aku. Proponuje polecany na forum Centra Futura CA770. Futury mam założone w 3 samochodach i zero problemów
            • gomar
              • 480
              Podepnę się pod kolegi temat. Też mam takie błędy jeśli chodzi o układ kierowniczy:
              Coding: 0000012
              VCID: 7F0772582EE6636
              4 Faults Found:
              00576 - Terminal 15
              Auto ogólnie działa normalnie, nie wiem kiedy się te błędy pojawiają, bo po skasowaniu i testowym kursie się nie pojawiły, dopiero po pewnym czasie jak znów zrobiłem diagnostykę kompem...
              SPRZEDAM! Nakładki na rączkę fotela do OII :
              http://forum.octaviaclub.pl/viewtopi...046007#1046007
              • qu_bek
                • 3936
                gomar, ja kasowałem błędy 18-stegi i też nie wiem kiedy się pojawiły...
                W sobotę miałem taką sytuację, że jak wyjeżdżałem z pod bloku to na dwójce auto mi się zdusiło i zgasło ale to pewnie wina tych świec :?:
                • gomar
                  • 480
                  Raczej nie, świece z tego co wiem potrzebne są tylko do odpalenia . Trzeba się przyzwyczaić do diesla, ja jeździłem benzyną 1.0 w Uno i też często redukowałem do dwójki jak trzeba było i auto dało radę, ten diesel + kilka osób na pokładzie ma gorzej z 2 "ruszyć" i łatwiej go zdusić. Mnie ciekawi tylko ten błąd układu kierowniczego, też mam słaby akumulator, ale póki co nie wymieniam, zobaczymy czy Tobie pomoże wymiana
                  • qu_bek
                    • 3936
                    gomar, no tak, ale jechałem sam i z 1 na 2 przerzuciłem standardowo...
                    Fakt do diesla tżeba się przyzwyczaić w szczególności, że wcześniej też miałem benzynkę :szeroki_usmiech
                    Jak wymienię to dam znać czy pomogło
                    • alxxx
                      • 1823
                      • ASZ 1.9 TDI PD 130 KM
                      diesla zdusić to trzeba się dobrze postarać, ruszałeś z dwójki? jakbyś powoli puścił sprzęgło to powinien się pozbierać.
                      • demmsi
                        • 966
                        Tylko te świece to rozumiemy że 4 zostaną wymienione :!: :diabelski_usmiech
                        • qu_bek
                          • 3936
                          alxxx, nie nie ruszałem... tak jak napisałem wyżej ruszałem z pod bloku - jeden, potem dwa i nagle zgasł... tak jak by się zdusił :!:
                          Raz miałem tak tylko, że na trójce ale już się więcej nie powtórzyło, aż do soboty.
                          [ Dodano: Pon 28 Sty, 13 15:14 ]
                          demmsi, nie inaczej :!: :diabelski_usmiech
                            • 11351
                            demmsi,
                            jak te błędy się pojawiają co jakiś czas, a z akumulatorem się nic nie dzieje
                            to może faktycznie być usterka zestyków stacyjki
                            • abstinent
                              qu_bek, na zimnym lubi się zdusić, zwłaszcza jak załadowany itp
                              ja zawszę ciągnę więcej i powoli na 1-ce :szeroki_usmiech
                              • qu_bek
                                • 3936
                                abstinent, dzięki za podpowiedzi
